pyrometer help... needle moving erracticlly
yeah it probably is the ground, mine did the same thing, and would even not move at all.
also do the block heater change the reading, mine goes up when the batt gauge goes down, and was at 300'(15' outside temp) today, right before it was started
Yeah, thats what mine does the same thing too.
Update
Hey guys a little up date on the pyro. I checked the wires, and everything seems to be tight. The only thing I haven't done is run the ground wire directly to the battery ground. The thing I'm wondering is, have any of you had a problem with the gauge its self? I 'm thinking it may be in the gauge its self.
Any clues?
Thanks, Tony
Any clues?
Thanks, Tony
My pyro gauge (Isspro) moves erratically while the grid heater is cycyling on and off. I've learned just to live with it. After the grid heater stops cycling, the needle reads correctly. Originally I installed the gauge and nothing worked. I decided to move the ground directly to the firewall (behind radio). This fixed the gauge and now works.
Later, Tony
Thanks, Tony
Up Date
Good morning everyone. I ran a ground wire straight to the battery neg. terminal yesterday. I went for a drive a few minutes ago. The needle only made 2 barely visible moves.
That is until I turned on the lights. At this point the needle bounces around when I use the turn signal, and when I press on the brake pedal.
When I turn off the lights it does not bounce around. I have changed the head light switch within the last 18 months. I also rarely drive this truck at night. Any ideas?
Thanks Guys, Tony
Thanks Guys, Tony
Do you in fact have the gauge powered by a switched source? Specifically one coming directly from the fuse panel?
Sounds as though you're feeding the gauge from a source that is in a circuit so to speak. Not directly from a fuse.
Just for grins and giggles, temporally run a 12vdc feed directly from the positive post of the battery. That way you can determine once and for all if there's an issue with the gauge (or the sensor and associated wiring).
