Pyro Installed
Old Sep 30, 2007 | 09:40 AM
gomerpile's Avatar
Pyro Installed
Alright i just got done instaling my isspro pyro. no problems except mouting the drive box and not having the right bits, the site i used called for a 5/16 where it needed a 11/32, but fixed that and all is good, so now my questions is, driving down the road at 70 WOT uphill in od at 16lbs of boost, it read 950-1000, is this normal for just a turned fuel pin?
Old Sep 30, 2007 | 11:48 AM
Yep, that sounds fine. Time to get after the fuel screw.
Old Sep 30, 2007 | 02:38 PM
gomerpile's Avatar
well i tried to today, but my new question is, what is the best way to get to it, i tried a deep socket with a pair of vice grips with no luck, how did yall get to them
Old Sep 30, 2007 | 04:56 PM
I use a 1/4" drive 6mm socket on a ratchet to mess with mine. I get the locknut with a 13mm box wrench.
For a first timer, it's easier to reach if you remove the throttle bracket from the side of the engine (2 nuts up top, 1 bolt down low).
Old Oct 2, 2007 | 06:28 PM
gomerpile's Avatar
alright i just went to try it, and this is what happend, i could only tighten the screw about a 1/4 turn, i dont know if i hit the collar or the locknut, but whats your opinion. and all i got was .5 lbs of boost and 100 more on the egts
Old Oct 2, 2007 | 06:32 PM
gman07's Avatar
You're probably up against the lock collar. Back the screw out (count the turns or mark the screw somehow), remove the collar and straighten out the threads if necessary. Put it back in and then see if you can get it to go farther.
It'll be worth it
Old Oct 2, 2007 | 07:26 PM
gomerpile's Avatar
is there any way to remove it without pulling out the whole screw. and if not if i need to fix the threads, what are the threads, metric-domestic, fine-course?
Old Oct 2, 2007 | 09:14 PM
Caver Dave's Avatar
Unless you have Lilliputian sized hands or are yanking the top off the pump (say, to install the 3200spring?)... nope
Metric and you *WILL* need to clean them up a bit... the collar is spot welded to the screw and takes a few bites when removed
Old Oct 3, 2007 | 03:05 PM
gomerpile's Avatar
any idea on the thread size i.e.-M ? X ?.xx. can someone fill in the ?'s
Old Oct 3, 2007 | 03:26 PM
RumbleFish's Avatar
threads are 8mm x 1.00
or you could order a new fuel screw with the user-friendly 6mm hex head. I can send you a pic of it if'n you'd like. p/n 1 463 402 423-000. it will set you back about $18 at your local pump shop.
Towrig
Jun 28, 2004 08:43 AM
PADZZ
29
Mar 31, 2004 05:25 PM
Steve5.9L
Nov 12, 2003 02:08 PM
wannadiesel
Apr 19, 2003 10:50 PM
