Pyro finally done, some numbers
cruising at 60 im seeing 600 constant
and at 30 MPH I can put it in 5th, and floor it, and never exceed 1000!
(thats on an around 30 degree day)
I have done these:
(pre-turbo pyro)
a few turns on the full fuel
star wheel bottomed
2 turns at the top
pin set deep
4in DP
timing bump
What do ya'll think??
I have done these:
(pre-turbo pyro)
star wheel bottomed
2 turns at the top
pin set deep
4in DP
timing bump
If this is a play truck, run the fuel screw in so that on a sustained WOT pass, the EGT's hang around 1200*F. Then turn the star-wheel back up to reduce the no-to-low boost smoke.
I've driven the truck and they feel like 3.54's to me. #'s sound good, JR
Did you get the pod on the pillar? I'm out playin in the garage all day today, and I've got light this time, so stop on over!
Yep, im runnin 3.54's as far as I can tell. The big pipe makes it sound a lil higher, but I can easily grab 100+ in a matter of seconds.
and reverse is like 50 MPH! need an underdrive unit.
I plan on runnin the full fuel in considerably, Greg and myself only ran it in till the buggered up threads allowed, probably a good 2, wouldnt u say Greg?
Im going to play around with the Smokey pin, maybe give gregs a try before I mess with mine.
The truck is a daily driver, play, and work. For now anyway. Till I find something 4x4, and x-cab. Then it'll be my little hotrod. Im thinkin S300, RV injectors, water/meth, maybe play with propane.
My actual goal is 400 RWHP, and as much torque as possible (I love torque)
Yeah, im hoping by the time it warms up enough to give me trouble with EGT's, the S300 will be here, and the water/meth will be done.
6.7L MegaCab
30
Nov 10, 2011 10:36 PM
lessismore
Nov 12, 2010 08:50 AM
SMOKIN-U
31
Jun 29, 2008 12:07 PM
