Pump Rebuild
Pump Rebuild
I got my truck back a few days ago after the rebuild. It did solve the hard starting problem. It takes maybe turns 2-3 turns then fires, unlike 20 turns before. I got the 3200 GSK spring installed too. And wow, it feels weird to be able to drop into 4th going 55 mph and have good strong power right to the upper RPM range. Only had it about to 3000, but wow does it sound evil like others stated
. After the rebuild i seemed to have lost a litlle bit of boost, but it was suposedly set CLOSE to the settings before. I think i gotta crank it up some more. I only see about 23 PSI and i got POD's. Other then the 3200 RPM spring i have no internal fuel pump mods.
Temps are great even in the Upper RPM range.
Jeff
. After the rebuild i seemed to have lost a litlle bit of boost, but it was suposedly set CLOSE to the settings before. I think i gotta crank it up some more. I only see about 23 PSI and i got POD's. Other then the 3200 RPM spring i have no internal fuel pump mods.Temps are great even in the Upper RPM range.
Jeff
