Pulling the head
Does any body know the part numbers for the aluminum intake horn gasket. I have my intake horn off all the time so its kinda dumb to get the paper ones id like one i can reuse.
www.haisleymachine.com sells it. I don't know if its a Cummins part, they might make it themselves.
Use a Scotchbrite disc instead of a wire brush.
) Scotchbrite will make the bearings
if you leave ANY of the residue on or in the engine (been there, done that as a "green" wrench) it`ll waste the bearings REAL quick. I only use scotchbrite/roloc discs on parts that can be thoroughly cleaned prior to re-installation. At work I use a wire cup brush for deck surfaces/heads and clean clean .... then clean some more.
I have some grinding discs that are alot softer then that so I'll just use them either them or the rubber ones
