Pull Cable Question
Old Jan 21, 2011 | 05:25 PM
ebteckx's Avatar
Pull Cable Question
So I have been searching the forum and have come up empty. When you gut the solenoid and hook the pull cable up, what do you do with the two wires? I know you dont hook them back up to the solenoid but do you hook them together to complete the circuit for the ksb? Thanks guys I appreciate it in advance!!!
Old Jan 21, 2011 | 05:52 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
just hook them back up. its just like hooking them together, just easier.
Old Jan 21, 2011 | 08:42 PM
92betsy's Avatar
I just tied them together when I gutted mine.
Old Jan 23, 2011 | 03:11 AM
ebteckx's Avatar
do they actually need to be hooked up at all? I thought one wire went to the ksb but after looking at it, it doesnt look like it. Ill have to consult my fsm...
Old Jan 23, 2011 | 05:13 AM
dzl_damon's Avatar
You don't need it as long as you have taken your FSS and gutted it. If you havn't, it will be closed. Limited fuel if it is cracked and wasn't shutting off before.
Old Jan 23, 2011 | 09:51 AM
NE frmhnd's Avatar
The wire for my KSB comes out of the plug back by the fuel filter. It doesn't feed off the FSS.
Old Jan 23, 2011 | 11:10 AM
BC847's Avatar
1st Generation Admin
It is best to not connect the two wires to a gutted FSS as it could overheat internally and present trash to the IP. Just connect the two wires together and insulate.
Old Jan 23, 2011 | 11:45 PM
ebteckx's Avatar
Thanks guys! I got the pull cable working and I did gut the FSS. Ill connect the wires and insulate them. I wont be driving the truck for a while now though. Got the cable all hooked up and the oring behind the shut down lever blew... lol So i spent the evening swapping my good tires onto my 78 gasser club cab just incase of snow. killer week ahead at work so I dont know when ill be able to pop the top on the pump and fix it. I think this has been seeping for awhile and messing with it finally popped it. Oh well thanks guys!!! Ill let you know when shes running again!!
90firstgen
Apr 13, 2008 05:48 AM
Kirk T
Sep 20, 2006 07:19 AM
A-Poc
Dec 2, 2005 05:58 PM
Boatnik
Oct 29, 2005 08:29 AM
hellotbone
Oct 7, 2003 06:54 AM
