Pros and Cons of driving a 47RH TC in lockup
Old Mar 7, 2011 | 06:54 AM
ClassA4x4's Avatar
I've finished putting some pressure switches as well as a manual switch for my 47RH TC lockup and I have been driving this 12k# motorhome with TC locked up quite a bit. I have it setup so that it locks on at 44 mph and turns off when boost is above 8 psi or when the speed goes under 25 mph (I wish it's 35mph though).
I must say the rpm drop is worth it. However, i'm curious about the side effects of driving with a transmission with the torque converter locked, especially in a heavy vehicle like mine. The engine seems not to care, but how about the transmission?
Old Mar 7, 2011 | 11:39 AM
Rampage1967's Avatar
As long as you don't slip the converter clutch or the internal clutches & bands in the trans it should run cooler with the converter locked.
Old Mar 7, 2011 | 11:00 PM
JQmile's Avatar
I smoke out everyone within a quarter-mile radius with a 14mm pump and 6x16 injectors if I use lockup too much....other than that I see no downside.
jwb600
13
Feb 3, 2008 10:53 PM
SPINPOSI
Aug 24, 2006 10:44 PM
Ironstone
Apr 25, 2006 05:57 AM
mr T
Oct 25, 2004 09:22 PM
mr T
Sep 13, 2004 08:27 PM
