Probably Dump Lift-pump Question
Old Apr 16, 2007 | 11:23 PM
BearKiller's Avatar
Question Probably DUMB Lift-pump Question
Just out of curiousity, I read somewhere that a fuel-pump block-off plate for a small-block Chevy will fit the Cummins.
If that be the case, will a mechanical lift-pump from a small-block Chevy work on the Cummins??
Dumbest question, so far; but, who knows?? >> it might just work.
Old Apr 17, 2007 | 06:37 AM
G1625S's Avatar
It may very well bolt up...haven't tried. Problem is, any mechanical gasser pump is not designed to flow the volumed needed by our engines. All a gasser mech. pump has to do is hold X pressure at the needle/seat of the carb and keep that little bowl full. The cummins is flowing in a constant loop both from the pump overflow and the injector overflow. Lot's more volume.
Old Apr 17, 2007 | 06:45 AM
johnny5.9's Avatar
Gasser pumps aren't designed to pump a fluid as viscous as diesel either. So who knows how long one would last when asked to do so.
Old Apr 18, 2007 | 01:30 AM
bgilbert's Avatar
It's definately is not the small block chevy or mopar. The correct block off plate is from a big block chevy. BTDT. As far as what fuel pump would work, you got me.
johnny5.9
May 7, 2015 10:43 PM
capt.Ron
Feb 25, 2014 07:52 PM
bsj04
Nov 21, 2007 08:57 PM
bostongsx
Feb 3, 2007 05:50 PM
Spooler
May 17, 2006 05:37 PM
