Power steering
Dan, not sure on your 90, but on the intercooled model years, make sure and remove the oil temp sensor and harness, before attempting to remove the vac pump and PS pump. Many a folks have sheared the sensor right off of the engine over the years.
The vac pump and PS pump is best done by removing as an assembly, then separating the PS pump from the Vac pump on your work bench.
The field service manual is very detailed on this procedure.
Check out Jim's thread on rebuilding the Vacuum/PS pump assembly....should show you what you need to know.
https://www.dieseltruckresource.com/...orking-165546/
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
