Power!!!
Old Apr 13, 2008 | 02:51 PM
Bo-man's Avatar
well it depends on if i want a jeep or not. its either get a jeep and have it half @$$ jeep and a half @$$ truck. or take that 5 grand and make my truck a work of art.
Old Apr 13, 2008 | 02:54 PM
Alwaysworking's Avatar
alwaysonDTR
for 5k you can do alot but you might need a clutch too.
Old Apr 13, 2008 | 03:16 PM
Montana2x2's Avatar
We had a 91.5 at the ranch and put in Bosch 190's when it needed injectors. They gave some power and were not too bad on egt's. I think an upgraded compressor would have allowed us to safely add more fuel.
Old Apr 22, 2008 | 08:07 PM
SkinnyBTN's Avatar
I just wanted to see if we could get this thread going again to help everyone out. If ya had $5000 what would you do? Custom pump mods to flow the bigger injectors, larger turbos, tranny mods, cosmetics too, etc. $5000 = _ _ _ _ _ _?
Old Apr 22, 2008 | 08:43 PM
I was told that the stock sach's clutch will hold close to 400hp if you dont do like 2nd gear launches and stuff.
Last edited by Crossy's son; Apr 22, 2008 at 08:45 PM. Reason: to add quote so understandable
Old Apr 24, 2008 | 06:53 PM
tboling's Avatar
To make some cheap power! 366 gov spring thats a must. cut the afc fuel pin and grind the afc foot. turn up the fuel some take the timing up a tooth. a 16cm housing on a 35 or 40 is about the cheapest way to go or your stock h1 with a 12cm waste gated housing or 16 cm. Make sure u have gauges please don't melt another 5.9. If u need some tips give me a pm.
Old Apr 24, 2008 | 10:16 PM
daking's Avatar
for five grand you could do so much, twins big injectors, fully biult pump, fully biuld tranny, rear end, exaust, im at 2500ish and i only need the tranny
Old Apr 25, 2008 | 01:15 AM
C/PRD/'s Avatar
HAHAHAHAHAHAHA CK the tranny is the expensive part. Are you gonna put in a 47rh or just build the Non Lockup? I could spend 5G's on my 47rh easy.
Old Apr 25, 2008 | 03:53 PM
SkinnyBTN's Avatar
If one were to go to a 14mm H&R and 4mm cam what all would that entail? Could it still be daily driven? Can a 12mm pump maxed handle 6x16 - 6x18 edm injectors? Would an HX40 be enough, temporarily, for the said injectors? I know its a lot of questions, but it might help a lot of folks out. Definately me. Thanks!
Old Apr 25, 2008 | 10:51 PM
daking's Avatar
14mm and 4mm, yes daily, as long as there enough fuel pressure
i have 6x20s and a 12mm, yes but your not getting max power, 6x14s to 6x16s would be max if your not going 14mm
you would fry the turbo, even with a 12mm, you would easly over boost it or snap the saft, i run a hx40 and ht60 and it seems fine
joel
Old Apr 25, 2008 | 10:53 PM
daking's Avatar
on the tranny im using th non lockup, and im going to get the parts and rebiuld it, i might spend more then 2500 it depends on what i get
joel
Old Apr 26, 2008 | 08:21 AM
SkinnyBTN's Avatar
Thanks man! I am pretty sure I'm gonna run the 14mm. Can one run the 14 H&R w/ out the 4 cam? I plan on the cam also, just curious. And to run the H&R and cam is anything else required so as not to burn it up?
TRANNY - I'm wanting to rebuild mine myself also, but have no idea how. I'm gonna try and find a good book. Anyone know of a good tutorial book like the ve pump book/dvd? Final? For now W/ running the 14H&R, 4 cam, 6x18 injectors, HX40 temp., and a good tranny could the truck still be hauled w/, nothing extreme? 4 wheelers, single truck, etc. Would water meth. system make it possible or safer? Again, thanks for all the great info!
RAK GUY
Apr 5, 2003 10:28 PM
powerwagon440
Jan 20, 2003 08:50 PM
pwabbott
14
Dec 20, 2002 08:23 PM
Garz
Nov 17, 2002 02:02 PM
