Positive and Negatives of The 3200 Spring
Old Apr 3, 2005 | 12:04 PM
  #31
Took a little hunting but I scared it up.
https://www.dieseltruckresource.com/...threadid=57415
Best set of directions I've seen. Makes it highly unlikely that you'll screw up and drop a valve in the engine.
You won't need to butcher the spring compressor, though.
edit: Here's another good one.
https://www.dieseltruckresource.com/...threadid=62572
Old Apr 3, 2005 | 12:25 PM
  #32
Den's Avatar
Den
Thanks Dave!
Den
Old Apr 3, 2005 | 04:46 PM
  #33
Bushy's Avatar
Patron Saint of 1st gens
When you use the spring compressor we've found that it works well if you "screw" the spring tight onto/into the compressor tool, *then* crank the handle on the compressor to squeeze it together....from there the removal and install of the new spring is fairly easy to do.
Like any other spring replacement, just use some care when you install the keepers....cover the surrounding area with a couple rags so if, on the off chance, the keepers go for a fly on you they don't drop down any open holes...not fun...
bob....
Old Apr 3, 2005 | 07:45 PM
  #34
flyingd's Avatar
I was wondering if installing the 60# springs will cause excessive wear on the cam or any other parts
Old Apr 4, 2005 | 03:45 PM
  #35
I would move the valve adjustments to 10k. They will cause more wear, but I wouldn't call it excessive.
hounddogks76
Aug 31, 2012 09:22 AM
92smokin blacky
Oct 3, 2010 07:21 AM
BurrisWill
Jan 25, 2009 08:23 PM
ClackClack
Feb 2, 2007 07:46 PM
chadrock
24
Apr 1, 2004 06:10 PM
