pop off valve a/c compressor
Old Jul 9, 2011 | 10:12 AM
hounddogks76's Avatar
Whosdonit....between the two of us, maybe one of us can figure it out..lol
And good guys like maybe368 batting for us!!!!
Old Jul 9, 2011 | 10:22 AM
deanhinsley1963's Avatar
are you sure you are not overfilling the system? 134a does not fill like r-12 in that on mine 2-cans fill it. If you fill till there are no bubbles in the sight glass it is to full. With a empty system try it with just 2 cans.
Old Jul 9, 2011 | 11:48 AM
gadget.35-06's Avatar
Originally Posted by whosdunit
thanks mark, can we install bigger dryers??? If this seems like a dumb question just over look some of us.
If you can get the proper fittings to splice into the liquid-line hose and have the space to mount a larger inline filter-dryer compatible with the refrigerant being used I see no reason why not. Sporlan and Alco(Emerson) come to mind as prospective brands. Just make sure you secure 'em so vibration doesn't tear 'em up!
A word of caution, though: I did say LIQUID line...Early in my career I made the mistake of splicing a filter-dryer into the DISCHARGE line and the hot gas melted the aluminum silcate dessicant...WHAT A MESS!!!! You can bet I'll never do THAT again!!!!
Old Jul 9, 2011 | 03:59 PM
whosdunit's Avatar
There you go Hounddog, just pulled the grill, used a wash -wand( not to close or to much pressure)to make sure evap-core clean.One of the problems i had w/ usin the gauges( my first time)put can on yellow line, open w/ mtr., runin, comp., on high,open blue ****(lo/pr- suck) left red(hi/pr)**** closed. I'm goingto stop here and let you guys that know how to do this part right --please tell me & hounddog what to open & close, 2 people have given me inst., both different? So how boutit???
Old Jul 9, 2011 | 05:58 PM
maybe368's Avatar
You always put the freon in the low side, AS A GAS, if you turn the can over and introduce as liquid, you can blow seals. That said, sometimes you have to kick it in the behind by quickly turning the can over. As you put in the gas, watch the sight glass, when it is ALMOST clear turn off the gas and watch the glass, if it doesn't clear up completely, introduce a little gas at a time until glass is clear. The reason that you don't want to put the gas in until it is completely clear the first time around is because it is very easy to over pressure and blow seals. The best time to do it is on a hot, DRY, day, like any day in Phoenix in June. High humidity days really lower the efficiency of ac and it can be difficult to put the gas in. This is all done with the system pumped down and holding a vacuum, if you are not just topping off a system. Also the Narcotraficantes didn't get me again, because I made it back to Phoenix with all body parts intact......Mark
Old Jul 9, 2011 | 06:00 PM
maybe368's Avatar
Another thing, the pressure readings don't mean a lot if you don't know the atmospheric conditions where you are. There are charts to tell you what the reading should be for any given condition...Mark
Old Aug 4, 2011 | 01:28 PM
Ok guys.....finally got some where on this deal. Replaced the crush gaskets and o-rings, because it wouldn't hold a vacuum, then my buddy who is a mechanic at work...put the guages on it and started charging the system. High side got up to 350 (it's only 85 hear today) and then i heard him start cussing me.....lol...this is where itn gets good! I had left a piece of cardboard in between the condensor and the radiator from last winter. I had missed it when i looked before. After that the high side is reading 250 and the low side is reading 30. Thermometer got down to 60 in the vent, not great, but better than it was. He thinks it's still alittle low on freon, but i ran out.....gonna get more later. This is with a new expansion valve also.
Old Aug 4, 2011 | 06:57 PM
jughead's Avatar
do not clear the sight glass with 134. on my 90 it is too full been using it for about 8 years and for maximum cooling on mine it always has bubbles
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
kwikspool
13
Jan 6, 2005 07:04 AM
97RAM
Jul 29, 2004 08:58 PM
NJMurvin
13
Jul 12, 2004 07:31 AM
