pop off valve a/c compressor
I didn't either.....the fsm shows one on the high pressure line....but this little booger is right on top of the compressor in front of the high side. Was charging the system after vacuum yesterday and the vent thermometer would make it down to 60 degrees and the relief valve would blow. then the temp would go back to 72 out of the vent. Makes me wonder if i have a blockage in the system, or would the expansion valve cause this?
According to the FSM, the high pressure relief valve is on the discharge mufler and activates at 450-550 psig and reseals itself when pressure returns to normal. It also says that pressures rise when air flow is restricted, have you checked your evaporator to see if it is blocked up? It also indicates air in the system, but since you pumped it down and it held vacuum, this is not likely. If your problem is in the compressor, it coud be bad, is it aftermarket?...Mark
There is a pretty good diagnostic flow chart in the FSM. I was talking about the fins. Sounds like maybe a bad compressor, but I would try some of the diagnostics first. I do know that the best time to charge an ac system is on a hot, dry day. The system is most efficient on those days. I assume that you had gauges on the unit when it vented, did you notice the high side pressure when it happened? ...Mark
we had the low side hooked up, but the hose for the high side wouldn't fit. The fitting on the high side of the truck was to small, so i got an R 134 adapter to put on the line today and try the gauges tomorrow.
There is a similar thread going on right now and it makes me wonder if maybe the original compressor is not compatible with 134-A. I know newer ones are and I have no personal knowledge the originals aren't, maybe somebody smarter than me will chime in...Mark
Hounddog, i'm having same problem,,,,,,don't know how to retrive my 134 that i just putin( anyone can jump in and tell me how), . Guess i will pull it all apart again. Do the dryers on our trks., have screens or filter in them???? Keep us posted & if you get it figured out ,,,,,let us know.Good luck.
. I don't know if you can, but it shouldn't be necessary. There is a really good trouble shooting guide in the FSM. I am coming home tomorrow and I can scan it in for you. Should be home by mid-afternoon, if the narcotraficantes don't kill me
...Mark
