Pop!!!
Pop!!!
OK this has me stumped. I can feel a knock or a pop under my feet when im driving on uneven ground, like driving across ruts on a dirt road. I cant hear it necessarily but i can feel it. I first thought it was a busted shock or a shock with the bushing gone but theyre fine. Then i thought maybe a spring shackle but they seem fine. Everything seems to be in order. It seems like it might be stemming from the front left wheel. i crawled under and pulled and pushed on everything i could lay a hand on.... nothings loose. Its gotta be something, any hints??
Someone on here suggested that it may be the axle spring u bolts comin' loose. Tighten up the nuts down. I always keep an eye on Tread subjects of popping noises, and the common factor is that all complaints come from owners of 4 x 4 trucks.
There is a bushing inside the eye as well. you would have to pull the spring out to see it.
where is the spring eye bolt located? and im gona go check u joints when drivin down dirt roads sometimes not often it feels like my axle is gona fall under my cab
kinda wonderin what it is makin it fell like that
Stiffler
Feb 19, 2003 03:38 PM
B-Peterson
20
Dec 4, 2002 07:03 AM
