The left/right turn pop noise
Does anyone know what that pop noise is when i turn the wheel to the left/right all the way, (usually while entering or exiting a drive way)? I'm guessing it's fairly common since most the deliv. trucks where i work do it too. Just had the u-joints, tie rod ends, and drag link replaced.
Re:The left/right turn pop noise
Its the springs. Since a had the lift put in I haven't heard it once. The factory puts slide shims between the leafs and the new lift has none.
Nascar Mark,<br> What about on a 2wd? Mine does the same thing and my brother thought it might be the control arm bushings. With Okie replacing them and the springs I wonder what it could be?<br><br>Paul
Have you checked the upper kingpin bushings? I replaced mine today and the popping you describe is gone along with a few other problems.<br><br>nascarmark- fwiw, my factory springs do not have shims.<br><br>Jay
[quote author=Jbolt link=board=9;threadid=11968;start=0#113405 date=1047177410]<br>Have you checked the upper kingpin bushings? I replaced mine today and the popping you describe is gone along with a few other problems.<br><br>nascarmark- fwiw, my factory springs do not have shims.<br><br>Jay<br>[/quote]<br><br>You have to take the springs apart to see the plastic shims.<br>
[quote author=nascar mark <br><br>You have to take the springs apart to see the plastic shims.<br><br>
I don't know about the 4WD, but on 2WD the popping noise on full turns is caused by the spindle stops. The spindle has an extended boss that contacts the lower control arm to act as a stop. If the stops make contact while the suspension is in motion there will be a pop.<br>Applying a big gob of chassis grease to both stops will cure the problem.
[quote author=ZONE5AB link=board=9;threadid=11968;start=0#113670 date=1047253524]<br>I don't know about the 4WD, but on 2WD the popping noise on full turns is caused by the spindle stops. The spindle has an extended boss that contacts the lower control arm to act as a stop. If the stops make contact while the suspension is in motion there will be a pop.<br>Applying a big gob of chassis grease to both stops will cure the problem.<br>[/quote]<br><br><br>Yep, my 89 and this 93 both did/do it. I just try not to go all the way to the stop. Sounds worse going over uneven terrain against the stop. There are angle cut stops on the rear of the spindle that contact the arms, funny setup.<br><br>J-eh
Mine makes this noise also. Not every turn, but a lot of 'em. This is not full steering turns, just making corners. I wonder if it is loose shackle bushings/bolts? Nothing feels loose in the knuckles or steering linkage. I plan to jack up the front by the frame and let the front suspension hang so I can check for something loose.
bailer6334
Jun 20, 2010 09:50 AM
VikingDiesel
Sep 10, 2007 12:09 AM
052500#1
Jan 21, 2006 12:53 PM
