pod q's
You could have your stockers EDM'd for about 400, but if they are at high milage on the tips, it's not usually worth the time. Pry the jingle out and get some POD's and a stage III or IV and you'll be rompin all over town with a cheap smile on your face.
Ya its pretty good. Im gonna get a 60mm upgrade for either it or my h1c in the next month or so. Just holler at me when youre heading this way and Ill be sure and get it to my house in stephenville.
Most say that combo will give high EGT's, especially when towing. I'm running that combo on a 12cm2, she'll get hot but only when I'm heavy on the throttle. Power wise- I ran 288/940 on a dyno a couple of weeks back. I may have had more but my WG was not adjusted properly cause I only pulled 28 lbs.
I run that combo and towing around 10,000lbs on open flat ground mine stays around 950, under heavy load it pulls fine and egts are easily controlled but like anything else you could overdue it if not paying some attention. This was before I upgraded to the 4" exhaust...which I'm guessing is only going to drop the temps more at wot.
BrokeSolid
21
Feb 3, 2009 09:36 AM
scottrod
Dec 13, 2002 03:06 PM
Scotty
40
Nov 28, 2002 09:37 AM
