pod q's
I haven't clock my mileage since the install. I noticed a big power gain but I also did this at the same time as a new head and a HX35 stage 3.5. I got mine from Ebay and they were reasonable and fast delivery. If I would of had the money I would of gotten a set of EDM's instead, just beware the pod's do run on the hot side.
Im running pods, and Im sure Ill get accused of BS, but whatever--the 27.x mpg Ive claimed in the past were on Pods. Now that said, I dropped from 18.5 to about 17 when I first put them in with my auto.
Although my odometer doesn't work I am gonna guess I'm getting pretty decent mileage as long as I keep my foot out of it. I can drive 6 days on a tank as long as I drive easy. Not grandma easy just not aggressive. Or I can blow through a tank in less than 2 days having fun with the smoke and burnt rubber. I would guess I'm around 300 h.p. but have never dyno'd. I plan to soon. I got mine from PDR.
does anyone know where i can get some used pod's or used injectors for a little cheaper, can i have my stockers turned up a little, whats the best bang for the buck! im broke and wantin power!
i have it..........in my room, can get one of the bolts of the top of the pump so no dice maybe when i have a couple days off. but im lookin for more fuel and more air so injectors and turbo!
for a budget start with the gov makes a big difference, i'm guessing you turned up your fuel screw as far as you felt safe?
which bolt?
what turbo do you have now? stock? with which housing?
which bolt?
my pump mods are exactly where i want 'em and the gov. will have to wait b/c of that dang bolt, iu wand some 190's or pod's for cheap, and my turbo is stock im also gona upgrade it soon. i assume its an 18cm housing
