plate lights went out tonight?
Old Nov 27, 2007 | 07:37 PM
ryan10's Avatar
Hey guys, tonight both my plate lights went out. what should i check? also, what can i hardwire these into? can i just wire the plate lights into the taillights?
thanks
Old Nov 27, 2007 | 07:44 PM
ofcmarc's Avatar
One or both lights?
Check ther bulbs.
Check the wires that run to them under the bumper. Sometimes they break.
The lights are tied into the taillights if you follow the wires back to the harness.
Old Nov 27, 2007 | 07:55 PM
Free89W350's Avatar
If you take a look under the bed by the back bumper somewhat between the driver side and middle you will see a T type plug harness. This is where all the rear lights are connected. Follow the lights from the license plate to there plug either at that T connector or in between there and the lights. Pull the plug and check for corrosion also take the covers off the license lights and check the bulbs and for corrosion. If you have corrosion get some electrical contact cleaner and also some dielectric grease and then clean and grease any corroded area. Hopefully it's just a dirty plug or a bad bulb.
Good luck, Ryan
Billm2004
May 10, 2009 03:34 PM
lovinCTD59
Apr 4, 2009 10:55 AM
xzaq103
Nov 18, 2007 02:01 PM
projected
Jan 1, 2007 12:09 PM
drew03
76
Feb 6, 2006 07:57 AM
