Plastic scraping noise from column????
Old Dec 17, 2007 | 03:59 PM
  #31
dieselcarpenter's Avatar
Talking
Thank you so much Dave!
Old Dec 20, 2007 | 05:36 PM
  #32
waldeckdiesel's Avatar
The nut method is a plus, but it's not 100% safe. I took apart 100's of tracotrs and things can still get screwed up. Believe me, a puller is worth it.
Old Jun 11, 2011 | 09:29 AM
  #33
BearKiller's Avatar
Originally Posted by ofcmarc
BTW, the "84 B-II didn't originally have a clock spring but we had converted the entire drivetrain and asscociated systems out of a '96 mazda B-4000 to work in the "84 body/chassis. (engine, Trans, t-case, axels, abs, steering colum, etc.) That was also a PITA but cool when done, sorta (it was still a "84 Bornco II )
We also fell into the Bronco II pit one time; a 1985 in our case.
For the most part, one can easily bury more money in a Bronco II just keeping it usable, than three lip-stick queens can spend in Walmart in a lifetime.
It was the worst money-pit I ever had.
Interestingly, though, there are three in my area --- all red and white now that I think about it --- maybe it has something to do with the color scheme --- all three still being daily-driven by the original owners; any one of these three will tell you that they have hardly spent a penny on repairs during their entire ownership.
I wouldn't buy another one with free gas for a life-time.
So far as needing a ridiculously expensive clock-spring to keep a few totally un-necessary functions alive, without a minutes thought about the matter, I would travel an alternate route.
I would put the HORN on a button on the dash; or, as someone else suggested, on a floor-button or a pull-lanyard = cool.
My preferences are for NON self-cancelling signals, so the loss of that feature is a benefit in my book.
As for cruise-control, I believe that is the second most dangerous technoligical feature ever introduced to driving, second only to the cellular telephone; I purposefully dis-able the cruise on everything anyway, so it's loss is no loss in my thinking.
You can spend that clock-spring money on something actually useful and not give it to the fatcats at Chrysler.
Old Jun 11, 2011 | 11:36 AM
  #34
ppiggppenn's Avatar
Yup the steering wheel center has threaded holes for a puller; start pounding on that steering column and micro switches along the tubing will start to break (anyone seen my four-way flashers?), and in my case the cruise control switches launched pieces all over the cab. The steering wheel puller kits are cheap, like $15-, and do all the common steering wheels.
Old Jun 11, 2011 | 01:06 PM
  #35
BearKiller's Avatar
What ^^ HE ^^ said; plus, you are gonna need that very same puller when you attempt to pull the drive-gear off the injector-pump main-shaft when it is time for a re-seal.
Old Jun 11, 2011 | 06:03 PM
  #36
joeytechman's Avatar
My clockspring is out of a 94 Caravan, plenty of those in the junkyard. Just had to clip the air bag lead. Also appeared to have the same ignition switch as well.
Diesel Jeff
Aug 18, 2008 02:36 AM
rjm022
Feb 4, 2006 08:02 PM
