permanent under-hood oil pressure gauge?
Has anyone mounted an oil pressure gauge in the 1/8" NPT port near the oil filter with the intention of the gauge remaining in place indefinitely?
Would the engine vibration destroy the gauge over time? Perhaps a gauge designed for a tractor would withstand the rough service?
I'd like to have a tiny (1" or less in diameter) gauge under my hood if possible. If anyone has done this and could post a photograph it would be appreciated.
TIA.
TIA.
Unless it was an oil filled gauge that cummins would shake it to death in short order. Even then I couldn't guarantee service length.
If you're putting it in the port that isn't used by the turbo remember that it is technically unfiltered oil, and wouldn't give any indication of a possibly plugged filter
I put mine under the hood because I can just have a quick look when I'm under there or if the stock gauge bottoms out I can have a quick look under the hood. Not a big deal. Plus it was only $20. I don't feel like doing the effort to get a gauge in the cab. Plus I don't have the extra money either with all the random crap that keeps going wrong eating up even more money.
Under hood will have to do.
Sent from my SGH-I747M using Tapatalk
That's why I put it in to begin with. I like to actually see a real world number once in a while. Don't need it all the time so I'll save a few bucks and some time and put it under the hood.
The idiot light works but the stock gauge is pretty lame in pretty much every pickup ever.
I put mine under the hood because I can just have a quick look when I'm under there or if the stock gauge bottoms out I can have a quick look under the hood. Not a big deal. Plus it was only $20. I don't feel like doing the effort to get a gauge in the cab. Under hood will have to do.
Frankly, if I could find small durable unobtrusive gauges (1" diameter or less), it would be great to have both oil pressure and fuel pressure gauges mounted permanently on the engine.
Thanks all.
The ideal location to pick up oil pressure would be from the main oil galley on the driver side of the block. Filtered oil with no chance of plugging up the gauge either. There are 2 - 1/8" NPT ports on the driver side of the block. One of which is where the factory oil pressure switch is already threaded into. The other port is just in front of that. It appears as though it might be difficult to get to for the later i/c motors with the vein style vacuum pumps. But maybe not. If clearance is an issue, you could use the rear-most port and build a "T" in order to install a pressure gauge along with the factory oil pressure switch. From then, just make up a length of hose or tubing to put the gauge where you want it. I think I'll do that this weekend.
As seen in the picture below, the 2nd port is just in front of the factory oil pressure switch.
While this is unrelated, I have a local pressure gauge which reads fuel inlet pressure to the VE (supplied by the Airdog). With the engine off, the needle was steady but as soon as I fired the motor, vibrations made it dance quite a bit. It only lasted a few weeks before it failed. It would register but stick in place after shutting down. Smack it with my hand and the needle would fall to zero. That said, this picture is old and I've since replaced the guage with a liquid filled gauge. The needle doesn't even twitch. I'll take an updated picture this afternoon if anyone cares to see it.
I Do not have an oil pressure gauge but I do have a fuel pressure gauge mounted under the hood. Its a liquid filled and has been on there for many years and is still working. It is mounted to a valve so if it ever does break off I can shut the valve, that is if it breaks on the gauge side of the valve.
sorry I couldn't resist
