Performance Pistons etc.
Old Jun 19, 2007 | 09:48 PM
mhuppertz's Avatar
Anyone make performance pistons and cranks?
Old Jun 19, 2007 | 10:03 PM
rbrettctd's Avatar
I dont think so. There was a similiar post months ago, and someone said Cummins was best available.
Old Jun 19, 2007 | 10:26 PM
LOGAN's Avatar
Muted User
factory crank and rods can take alot of abuse, not necessarily truck crank and rods but 5.9 cummins crank and rods, try arias or ross pistons for custom cut pistons.
Old Jun 20, 2007 | 12:15 AM
bgilbert's Avatar
www.scheiddiesel.com for Arias pistons. On the crank, most guys may have them cleaned/polished and lighten up, but not replace them if it's not necessary.
Old Jun 20, 2007 | 07:54 AM
Cowboy_Customs's Avatar
Just what kind of performance r u looking for in "Performance" pistons?? lol, I could send u to 3 other sites for days of reading and research.
Stock Cummins pistons are fine, just get the tops ceramic coated, and the skirts teflon coated.
Unless your looking for lower compression.
Old Jun 20, 2007 | 04:41 PM
dpuckett's Avatar
Cummins makes a marine piston with a ratio of ~15.3:1. Get enough air to go with it though, or you'll suck the fuel and run high EGTs. Even lowering mine half a point raised my EGT more than I wanted. But, I think when I get a good high flowing turbo on there, it should take up the slack.
DP
Old Jun 21, 2007 | 06:42 PM
mhuppertz's Avatar
Certainly don't want lower C/R, just a lighter, sturdier forged piston..
Old Jun 21, 2007 | 08:49 PM
OK, well, I would start with Sheid or Enterprise, N go from there then. They outta be able to point ya in the right direction.
Let us know what ya find im a lil curious myself.
Old Jun 21, 2007 | 08:52 PM
mhuppertz's Avatar
How is your recooperation coming along?
Old Jun 21, 2007 | 09:23 PM
mhuppertz's Avatar
I would like to lighten the reciprocating assembly a bit by using forged pistons with exotic coatings, lightening the crank by knife edging the throws, blue printing the rods after shot peening and resizing the rods, align honing the mains, balancing the assembly, blueprinting and squaring the deck, fire ring, etc. I also want to see if I can get mechanical roller lifters to work so I can use steeper attack angles on the cam. I of course will clay the heads to make sure the valves don't hit the pistons... I also would like to hog out the intake and exhaust ports, then make a bundle of snakes tuned exhaust header out of thick pipe and have it ceramic coated.
Anyone have a big bag of cash I could sort of have?
DodgeRam24V
13
Oct 27, 2011 11:28 PM
RollinCoalSmoke
May 29, 2009 09:20 PM
skynyrd
Jan 10, 2008 06:41 AM
turbo dreams
Nov 21, 2005 06:25 PM
ddestruel
May 10, 2005 12:17 AM
