PDR35/HTB2 as TWINS ??
Old Aug 21, 2004 | 04:42 PM
CrewCabCummins's Avatar
Could this combo be used with sucess on an overfueled/High EGT running 1st Gen? My temps get to high while pulling my 10k trailer. Or would I be better of just running the HTB2.. My PDR 35 is running a 16 housing presently...what do ya think?
Old Aug 21, 2004 | 08:19 PM
TexasHardcore's Avatar
Isn't that the turbo that Cody (NeedMoPower) wants? The HTB2?
Old Aug 22, 2004 | 06:26 PM
Stomp's Avatar
The twins that I am going to be putting on my pickup is a HX35 hybred with a 12 housing and a HT3B with either a 23 or a 26 housing. I wonder how your set up will do?
Stomp
Old Aug 22, 2004 | 10:38 PM
It seem's to work well together from what's been said about it..The question will be.. will that "LITTLE OLE" VE Pump be up to the task?? I think that If anyone's going to see if it work's on a 1st Gen.. it's going to be a guy like you/your truck.. It look's like you have the Fuel to spin em....HURRY I cant wait to see it!!
Old Aug 23, 2004 | 12:21 AM
Stomp's Avatar
Hey I just have to get the section for the hot pipe and I will have everything so it shouldnt be to much longer. Belive me I'll let you all know.
Stomp
Old Aug 23, 2004 | 12:34 AM
I cannnnnt wait !!
Old Aug 25, 2004 | 01:06 AM
Old Smoky's Avatar
The compound setup I built for my '92 uses a hybrid 35/40 and a BHT3B. Personally, I wouldn't want to run this setup with much less hp. I run about 55psi (I am lacking some compression). With a stock HY35 on top it spooled a little faster, but nothing to write home about. It spools like a 40 now. By switching to the compound setup I did loose a bunch of EGT. I'm not sure what you would see with your setup.
Mike
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
