Parts fix leaking fuel pin
Parts to fix leaking fuel pin
It appears my fuel pin is leaking (fuel dripping out of the AFC vent)
My question is where do I get the necessary seals to fix this problem? Do I have to get the whole seal kit, or can these be ordered separately?
Thanks
Thanks
you technically only need one O-ring. but if it is bad, there are a handfull of others to replace while you have the pump down that far. and the complete kit is only $20! the part no. for the kit is DGK-121. (i just did the repair last weekend. there is a very good how to in the sticky. its a piece of cake, other than the top rear screw holding the top on the pump. you will need a "good" ball-end allen wrench.)
On teardown take the time and sketch out and take notes on the position of the indexing of the throttle shaft so you can return it to its origional position, just 1 tick mark off and it will not start, this will save a lot of frusteration when you find it won't start. I use a digital camera to document my moves.
Also be sure to have a way to choke off the air incase of a runaway.
Jim
Jim
gaberichison
Dec 21, 2014 12:21 PM
Cowboy_Customs
Oct 18, 2011 01:46 AM
CTD_Neil
Jul 19, 2005 08:13 PM
