part #for stuff
part #for stuff
ok guys i got a prob local shop is stupid so i need part #
1 part # for 190 injectors nozzle tips
2 part # for a 3200 gov spring
3 part # for 16 cm2 turbo housing
www.piersdiesel.com. PDR and be done with it.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Heres a list of some of the more common part numbers too.
You won't find a part number for the 190's because Piers did the research to find what will work and they don't give out that info.
3521927 This is the casting number on the 16 cm housing <edit> oops that's the casting # for the hx-35 housing I think that the one for the H1C is different. I'll leave it up anyways just in case someone needs that #
#2 This is the only item you could get locally or somewhere other than an online vendor. Although it may take some effort, most local Bosch shops won't have a clue, even with the gov spring part number you still might end up with the HUH??? look from them.
#3 Without a part number good luck. Our online vendors sell this stuff at bottom dollar. Highly doubtful you'll get a 16cm housing any less than what PDR or any other online vendor sells for even with shipping price included.
Tid bit of info, the 16cm housing came factory on the 4 cylinder B series Cummins. Find that needle in the haystack, and you may get lucky enough to snag the 16 off it. Again good luck, pay to play, one call, one click, be done with it. I am as cheap as they come, so take it from me when I say spend it once, be done with it, its not gonna get any cheaper.
Originally Posted by JKM
What shop around here are you getting your stuff from?
You will pay less even with shipping from Piers. A local shop will pay the same as you can pay for the part... then they mark it up for their time to locate it and order it for you. You can expect a 40% markup. I agree with Bgilbert. Call Piers. They are excellent to work with. And they buy in more volume so they can give you a great price.
NoSparkplugs
06-24-2009 07:08 PM
77machomopar
01-24-2008 05:30 AM
Loopi
05-11-2007 03:32 AM
