P-Pump Swap (Pics)
Nice write up and pictures. It's kind of hard to explain what a p-pump is like to a ve pump owner. You don't need as much injector with a p-pump either, so they can make more power and run cleaner on the bottom end.
Is there a rpm diffrence between the ve and the p-pump engines? The reason I'm asking is when I did my fordcummins conversion my A518 decided to puke out the OverDrive. When I ordered my transmission they sent me a A618 with lockup. After getting the adapter plate, starter and toggle switches in place of the computer I noticed that I have a max speed of maybe 50 in third and 75 in overdrive. It seems like theres not enough rpm for this tranny to go faster unlike the 518. I was able to do easy 80mph with the 518. transmission.
Most deffinatly! Has a whole nother sound. I went to a meet with a bunch of guys to B-dubs over the weekend and a few of came over when i pulled up and they were like whats wrong with truck man it sounds sick, and after a lot of laughter on my part i poped the hood and there was the p-pump starin them in the face and then the drooling started
Got a set of 5x.016s on order and a Hx50 sittin on the shelf waitin to go on. I cannot wait to get those put on and bump the timing goin to set it at bout 22*. then be time to hit the Dyno!!!!
It's a function of the governor more than the capabilities of the pump. The P-pump governor is very complex and precise - a VE governor looks like it was stolen out of a Briggs & Stratton lawnmower engine.
sgreen, tell us what ,mileage difference you see, since everything else is the same.
What pump did you start with, I don't recall seeing in the thread.
Having both pumps, there's no comparison in getting power per $ out of a ppump vs a VE.
Im using a 180hp pump, I still getting bout 20mpg on the highway, even with the nasty 370s(thus the reason for custom injectors,lol). Should get a bit of a milage bump when the timing gets bumped, just depending on how well i can keep my foot out of it with the bigger injectors,lol. Power is no comparrison, I only have bout $1100.00 bucks in the p-pump swap itself so it is well worth the time and cost so far.
