overheating results are in...!
Old Jul 29, 2009 | 11:27 PM
jimbo486's Avatar
picked up an upper engine gasket set from cummins.
PN 4089649 | $213.20
i've never seen some of these smaller parts. i called cummins asking if they could name off the individual parts. they faxed me 2 lists.
if in fact, the valve stem seals are the blue tip pieces, there were only 10 in the bag. hmmm, the parts list clearly says there should be 12.
Old Jul 30, 2009 | 08:21 PM
jimbo486's Avatar
i need help identifying the parts. anyone done a head gasket with the gasket kit above?
Old Jul 30, 2009 | 08:40 PM
BC847's Avatar
1st Generation Admin
Well, . . . .
- head gasket (1)
- Valve cover gaskets (6)
- Valve cover bolt O-rings (6 - thin rubber)
- Exhaust manifold gaskets (6)
- Valve stem seals (6)
- Intake log cover-plate (1 big rectangular gasket)
- Grid heater housing and intake feed-horn (2 - 3" square gaskets)
- Fuel injector return line (6 - U shaped copper gasket things)
- Fuel injector seals (6 dime sized copper washers)
- Fuel injector sleeve (6 thin rubber square-cut O-rings maybe 1" diameter)
- Exhaust manifold to turbo exhaust housing (1 - 3" x 4" thin metal gasket)
- Thermostat housing O-ring (1 - Rubber, stepped on one side)
Did I miss anything?
Old Jul 30, 2009 | 08:46 PM
jimbo486's Avatar
only 6 valve stem seals? you sure? the parts list they faxed me says there should be 12 valve stem seals. makes sense since there's 12 valves in our trucks, right? i only have 10. time to call cummins... again...
Old Jul 30, 2009 | 08:48 PM
BC847's Avatar
DOH!! I was thinking cylinders.
Yes you need 12 valve stem seals.
Old Jul 30, 2009 | 09:00 PM
jimbo486's Avatar
are the blue tipped cup-things the valve stem seals?
Old Jul 30, 2009 | 09:03 PM
BC847's Avatar
are the blue tipped cup-things are the valve stem seals?
Yup.
Old Jul 30, 2009 | 09:13 PM
jimbo486's Avatar
well crap! i was right in my assumption only having 10. i was thinking that. i assumed there should be 6 or 12 of almost all the little stuff lol 6 square cut rubber washers/o-rings with a 1" ID...? i'm short 5. i'm gonna swap and compare kits with cummins tomorrow lol
thanks again for your help david!
Old Jul 30, 2009 | 09:41 PM
93flatbed's Avatar
When you got this kit was there an option for the 0.0020 head gasket, or did you ask?
Thanks
Justin
Old Jul 30, 2009 | 09:53 PM
jimbo486's Avatar
i believe i read somewhere that 10 (.010") or 20 (.020") over gaskets are available. i remember asking, but i can't recall if they said they were an option or not. i'm going back tomorrow to make sure i get all the parts i need this time around. i'll ask about a 20 over gasket for you and get a price, if it varies with the thickness.
if the head is distorted and needs to be machined, that's when the 10 or 20 gaskets are needed to retain the proper compression ratio, right?
Old Jul 31, 2009 | 05:43 PM
Yes, or if you are running big injectors and lots of timing and want to drop the compression half a point.
Old Jul 31, 2009 | 06:01 PM
blackfordd's Avatar
Jimbo,
I cannot offer any specific information about your project but you are obviously in good hands. What I can offer you is moral support and a second set of hands. Depending where you are in OC I am probably only 45 minutes away or so. Please, let me know if you need either of the above anytime. I can also swing through Long Beach for example to pickup something you might need on the way. Always up for "hands on learning" and helping a brother out.
Blackford
Old Jul 31, 2009 | 07:04 PM
jimbo486's Avatar
the offer is very appreciated. thank you! i'll let you know if a second or third set of hands would help out. my dad wants to help me with it, but he works days with rotating days off. we'll see how things work out and i'll be in touch with you if i/we need some assistance. it will definitely be a good learning experience. thanks again.
93flatbed, i asked the guys at the parts counter about a 10 or 20 over gasket and they said that they only have standards in their kits. at this point, not sure where to go for one.
Old Jul 31, 2009 | 07:51 PM
G1625S's Avatar
Not totally relevent, but here's some of my woes with pics of a 480000 mile 9mm head. https://www.dieseltruckresource.com/...s-t183813.html
Old Jul 31, 2009 | 09:54 PM
jimbo486's Avatar
yes, totally relevant! makes me feel a little better about what i anticipate to find on my head. i'm hoping i can toss the new gasket down and lay the head on top of it and be good for a while. thanks a lot!!
