Overdrive problems
Old Aug 30, 2006 | 08:33 AM
saltydog's Avatar
Overdrive problems
I have a 93 Dodge 1 ton 5.9 diesel. I have an ongoing problem with it jumping in and out of overdrive. It seems to be more prevalent when its raining and/or bumpy conditions. Sometimes it goes for months with no problem. Just returned from a 200 mile trip where it did it for the major portion of the trip.
Have discovered that it loses its ground to the overdrive solenoid. Have installed a switch to give it ground. This always makes it work but does not cure the problem.
Would appreciate any info and suggestion you may have that would alleviate the problem. Its annoying. Has anyone else ever encountered the same thing and if so what was done to correct the problem.
Old Aug 30, 2006 | 08:44 AM
flashgordon's Avatar
Go and look in the" STICKY" above were you just posted. there is a grate how to there. then come back and ask away there is menny that have fix there problem this way.....mine is a manual so this is the best advice that i can give
Old Aug 30, 2006 | 08:07 PM
The OD is grounded through the PCM - that's how it is controlled. The PCM is dropping you out of OD for some reason or another. If the speedometer is working properly the likely culprit is the TPS.
DJ Turbo.
Oct 13, 2011 09:11 PM
72demon440
Apr 27, 2007 10:45 PM
ouchman
Mar 9, 2004 01:36 AM
baldeagle
Sep 30, 2003 08:09 PM
olgraybeard
Mar 24, 2003 06:32 AM
