overdrive off problem
Old Jul 12, 2005 | 09:36 PM
charger 69's Avatar
I towed my 10K trailer this weekend for the first time in a few months and found I can't get the truck out of overdrive.The overdrive off switch doesn't work and the truck won't shift from overdrive to third under load by itself so when I did the big hills I had to pull it into second.All the wires were pluged in the back of the switch and I checked the fuses,any ideas?? Thanks.
Old Jul 12, 2005 | 09:50 PM
Micaiahfied's Avatar
i'm not an expert on the subject but from what i have seen on here overdrive issues seem to be related to the throttle position sensor (TPS) if that is the case, this link is a cheaper fix than a new tps
https://www.dieseltruckresource.com/...threadid=42003
hope this helps!
Old Jul 13, 2005 | 09:18 AM
Tuckerdee's Avatar
If you're not shifting in O/D while under load it's most likely that the TPS only needs adjusting. If it's never shifting into O/D, then it could still be your TPS, or perhaps your Vehicle Speed Sensor. If the VSS isn't working you'll have no speedometer as well.
Old Jul 13, 2005 | 06:14 PM
charger 69's Avatar
The speedometer works fine now its warm weather(didn't sometimes when its cold).How do you adjust the TPS sensor??
Old Jul 14, 2005 | 09:22 AM
Tuckerdee's Avatar
Here's a good description on how to adjust the TPS from Piers Diesel: TPS
Old Jul 14, 2005 | 08:04 PM
charger 69's Avatar
Hey thanks guys I'll give it a shot.
72demon440
Apr 27, 2007 10:45 PM
electrifried
Oct 10, 2005 07:11 AM
RTharaldson
Jan 24, 2005 09:27 AM
Eskimo
Aug 4, 2004 06:57 AM
Jones0027
Jan 15, 2003 02:38 PM
