Ok, Let's replace our wing window seals
Old Jul 24, 2014 | 05:59 PM
  #31
jimbo486's Avatar
I definitely don't want to break them either. I have the assemblies out of the door as well.
Old Aug 9, 2014 | 12:50 PM
  #32
jimbo486's Avatar
Found a trick. A little Goof-Off and some patience will release the "glue" holding the glass to the hinges. Got it!
I also discovered that seals that LMC Truck sells are made by Precision. I don't think there was much precision in their reproduction of the seals. They fit poorly. The original seals seemed to be in good shape. Still pliable and soft so I gave them a lathering in some rubber conditioner and reinstalled them. I decided to send all the door and window seals back yo LMC Truck and find a source for better quality and fitting seals.
Old Aug 11, 2014 | 06:24 AM
  #33
bannerd's Avatar
The only replacement seals that I was able to find was from the 80 style vent seals. You have two options, cut the seal to fit the top hinge.. or pickup a 80's style vent chassis.
Old Jan 28, 2016 | 03:20 PM
  #34
maybe368's Avatar
All good here!!
Wow, I'm tired. I only have 5 threads to check, I feel sorry for Jim Lane and David, bc847, they have thousands to check ...Mark
Old Jan 28, 2016 | 05:43 PM
  #35
Mark,
Thanks for taking the time to go over these threads.
Old Jan 28, 2016 | 05:54 PM
  #36
maybe368's Avatar
Mark,
You're welcome Oliver, I have always felt honored to have these threads admitted into the sticky, so I feel obliged to see to it that they stay useful...Mark
Old Feb 8, 2016 | 08:20 PM
  #37
samiam4's Avatar
I think the differentiation is the hole in the rubber for the pivot at the bottom. The earlier trucks had a metal support for the glass and are a *larger* diameter.
I don't think this will drop in a late model- without a sleeve.
pwrtripls1
Dec 12, 2008 02:43 PM
ouchman
Apr 15, 2006 11:28 AM
Hoss
Dec 10, 2005 02:30 AM
