Oil Usage
Old Dec 19, 2006 | 05:24 PM
Mike T.'s Avatar
Oil Usage
This is my first diesel truck and I'm curious if these trucks are prone to use just a little oil? I don't see any blue smoke when running and I don't have any leaks. I've checked the fluids and I don't see any mixing of oil and coolant. When I purchased the truck it was completly stock and wasn't abused.
Your thoughts?... Thanks
Old Dec 19, 2006 | 06:06 PM
Ace's Avatar
Ace
Yep, crankcase blowby comes out a tube on the driver's side of the engine down by the oil pan. Normally not much, mine leaves a few drops on the garage floor every night, and the bottom of the transmission is pretty grimy from going down the road. I think I used about a half quart in the last 2,000 miles.
Old Dec 19, 2006 | 06:17 PM
Mike T.'s Avatar
Thanks Ace, that makes me feel a lot better.
Old Dec 19, 2006 | 06:41 PM
rustbucket's Avatar
Smile
My 93 has less than 200,000 miles,and uses less then a pint between service times,around 6,000 to 7,000 miles.
Old Dec 19, 2006 | 09:59 PM
edwinsmith's Avatar
Mine gets about 19 MPG of diesel oil. Does that count?
Old Dec 20, 2006 | 07:45 AM
Mike T.'s Avatar
By your response guys I'll just assume a little usage is normal
Thanks
Old Dec 20, 2006 | 07:58 AM
flashgordon's Avatar
215,000 and used no oil between oil changes(5,000 miles)
Old Dec 20, 2006 | 08:56 AM
jw216's Avatar
198,000 miles, Have never added any oil between changes. 4000 t0 5000 mi.
Old Dec 20, 2006 | 09:00 AM
timb's Avatar
I guess it all depends on the engine. Mine has allways used 2 quarts between changes.
Old Dec 20, 2006 | 09:10 AM
Ace's Avatar
Ace
Yyyyyep. And just because you didn't add any doesn't mean it wasn't low!
But I'll assume everyone here is checking their oil level on a regular basis.
Old Dec 20, 2006 | 06:17 PM
ChrisLib's Avatar
Mine has 182k on it and has used about 2qts per OCI. No blowby but the RMS has leaked since I got it. It recently has gone up to about 1qt. per 150 miles...RMS is shot...GRRR so the CTD gets parked till after the holdays.
Old Dec 20, 2006 | 06:30 PM
Mine goes through around a quart between changes (6k).
RattlerSkin
20
Apr 8, 2007 11:48 AM
pybyr
Aug 28, 2006 06:33 PM
tfarmer96
Mar 23, 2005 11:06 AM
JohnnyH
Nov 15, 2004 09:21 AM
MR. GADGET
Apr 24, 2003 02:51 PM
