Oil pressure
Old Jul 20, 2014 | 08:33 AM
JustRamIt91's Avatar
Oil pressure
Ive been looking for the last 30 minutes and cant seem to find any #s. Does anybody know what the oil pressure should be at idle and at redline(2,200)?
Thanks
Old Jul 20, 2014 | 09:04 AM
sooty's Avatar
I think I remember the manual giving 7 psi as tolerable low pressure, my virgin 4bt hits 85 before the oil gets warmed up, 60 at operation temp of 180*
Old Jul 20, 2014 | 01:50 PM
j_martin's Avatar
Curb idle speed 6 psi min.
3000 rpm 30 - 80 psi
It's in the book.......as John Standley would say.
Most of us are used to seeing 20-30 at idle unless it's real hot, and 55-60 psi at speed when warmed up (regulated) , up to 80 when cold.
Old Jul 20, 2014 | 06:13 PM
Thanks for the info. Im buying a mechanical gauge and want to know what i should expect.
Old Jul 21, 2014 | 11:37 AM
GasganoFJ60's Avatar
Depending on ambient temp, 40-60ish idle psi - initial startup.
Cruise @ 60mph = approx 40-45psi @ normal opp temp.
@ normal temp idle = 20-22psi. (18-20 with AC)
I T'd my oil line off the same port the factory oil pressure sensor is located.
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
