Oil plug?
Oil plug?
I have oil dripping around my oil pan plug. I tighten it and that seem to stop the leak. It started up again, does anyone have a part number for the washer that goes on this? Cummins part #, I'm guessing it's a crush washer.
Although hardly anyone ever does it, the drain-plug washer on ANY engine is supposed to be replaced at every oil-change.
I have replaced the drain-plugs on all of my engines with FUMOTO valves and no longer have any of those issues.
I had wanted the Fumotos for quite some time, but they had always seemed more of a could-do-without luxury than a necessity.
Then, after personally witnessing no less than three different people on various vehicles who had that drain-plug reinforcing threaded-washer to break loose inside the oil-pan, necessitating removal of the pan to repair, I decided they were no longer a luxury, but a common sense way to avoid such problems.
hey-Hey!!!,
It isn't so much replace the 18mm crush washer/seal, it is aneal it prior to squishing it again. Hang it from a bit of welding rod over the edge of the table and heat it red-hot. Drop immediately into cold diet pepsi( leaves the finish cleaner than jus' cold water ). Probably 3-4 times per washer will leave them deformed enough that even we'd replace it.
cheers,
Douglas
cheers,
Douglas
Received 1,637 Likes
I just buy a pack of 18mm crush gaskets from my local ap supply, and change them each time.
No leaks ever.
No leaks ever.
jlipskoc
02-21-2007 12:13 PM
