Oil blowing out dip stick
Hi all!
I just replaced my injection pump a few weeks ago on my 91.5 intercooled 5.9L. I thought everything was fine, but now I am noticing large amounts of oil in the driveway. When I looked under the hood, I noticed an oil mess coming from the dip stick opening. When I secured the dipstick so it won't blow out, I noticed lots of oil coming out somewhereunder neath the truck. It seems there is a lot of pressure wanting to get out, but I don't know what to check first. My mechanic checked compression a few weeks ago, and he said it was fine, but he thinks I might need to replace my injectors now. Replacing injectors won't help the oil leak, will it? I had to add 6 quarts today, and I changed the oil only 2 weeks ago. ?
Also, not sure if this is related, but sometimes just off idle the engine runs very rough and shakes plenty. Any ideas? Can this be related?
Thanks for any insight!
-Jeff
-Jeff
Hi all!
-Jeff
-Jeff
Last edited by BC847; Mar 7, 2014 at 03:52 PM. Reason: short-cut to language quoted
Might also be a vacuum pump issue. The vacuum pump vents into the crankcase. If you have a large vacuum leak (bad booster, leaking or disconnected hoses, etc.) the excess flow goes into the crankcase.
Yea could be the Vaccum pump.
Just had a bus doing this same thing at work, pushing oil out the dipstick and the oil fill! Pushing it UP like 3 feet! Turns out it had a cracked piston ring, major blowby was going in the crank case.
I overhauled it, and it fixed it
You'd be crazy to do an in frame overhaul in the truck, easy enough to just pull the engine. And build it right, getting necessary machine work done to the cylinders. which im sure it needs
Please fill out your Sig with your truck info....so we know what you have, and it's options, mileage etc.
But definitely do as suggested. Start with the simple and cheap things first....crank case breather...remove oil fill cap etc. Then work up to the things that are going to cost more.
But if all the simple things are helping the problem then you probably have some major motor issues.
entire engine, bearings, rings etc. I would say $800-900 for parts and then less than 2,000 for labor. I wouldn't pay more than what thrashingcows has for posts.
I wouldn't pay more then what you have for posts lol. $1500 will get you a good used engine and then sell your old one for $500
Nimrod
17
Jan 12, 2004 09:40 AM
