Replacement Oil Dip stick?
Old Jul 24, 2007 | 03:34 PM
MOAGGIE's Avatar
Ok I broke my handle on my engine oil dipstick when I was replacing the lift pump. Went to local Dodge dealer, ordered one in, it is too short and the marks are way off. Parts man said "you may have to shorten your oil tube for this to work!" I didn't tell him what I really thought of his idea, but continued to push him to find the right one. THey even looked it up by using the VIN and it gave them a different part number which was in stock,but still wasn't right. ANy ideas as to where to look next?? thanks.
Old Jul 24, 2007 | 08:56 PM
Stamey's Avatar
I would think you could pull the handle off the new one and put it on the old one, if the metal part of the dipstick is still sound. I know I got a replacement handle for my dipstick, a billet aluminum one, and it was just the handle. I haven't actually installed it yet, as I am lazy and busy with bigger things.
Otherwise, check this out to see if it helps:
http://dodgeram.info/tsb/1998/09-06-98.htm
It appears to be a Cummins part, so youo might check there.
Chris
Old Jul 24, 2007 | 09:08 PM
Hillcountry's Avatar
Usually the handles are held in place by metal pins...perhaps you can drive those pins out and swap handles...clearly that dealer is not going to get you the correct part.
Good Luck!
Old Jul 24, 2007 | 11:50 PM
MOAGGIE's Avatar
Hey Stamey, where did you find the billet one? I wouldn't mind having an excuse to add some shine under the hood.
Old Jul 25, 2007 | 07:01 AM
Stamey's Avatar
From Bob Wagner, on here as "Bob Wagner". He does all kinds of aluminum parts for the underhood area of the Rams/Cummins.
Chris
DODGER BOMBER
Oct 18, 2007 02:40 PM
BuckeyeRed
Sep 5, 2007 12:15 AM
nates90
Dec 4, 2006 11:06 PM
Nimrod
17
Jan 12, 2004 09:40 AM
dodgediesel4x4
Dec 18, 2003 08:36 PM
