OD and cargo light buttons
Old May 10, 2006 | 10:22 AM
PeytonMaterne's Avatar
Neither of these light up when pushed. Can I replace the buttons with toggle switches. Or what would you suggest?
Old May 10, 2006 | 07:22 PM
The OD button is a momentary switch with a light. Pushing the button grounds a pin in the PCM, the PCM turns on the light, and locks out OD. Push it again, the PCM turns out the light and enables OD. So that one's a no on the toggle.
Cargo light would be OK as a toggle.
Old May 10, 2006 | 11:24 PM
flashgordon's Avatar
Before you go and by a switch for you cargo lamp remove it and check the bulb(of cours) but will your there check the conection on the wire to the socket...You just might find your problem..I did!!
edit I'm talking a bout the cargo lamp not the swith.
stratos201proxl
Jan 16, 2014 11:04 AM
GIT-R-DONE
Feb 17, 2007 06:50 PM
brandon's93
May 13, 2006 12:40 PM
banks
May 9, 2005 03:37 PM
darrin
Nov 28, 2003 05:58 PM
