best location for a leaf
I installed a few new leaf springs a while back and am now looking to add 1 or 2 more per side. I heard that overload springs were created to give a softer ride until loaded, then they work. Where as adding to the main pack adds stiffness at all times.
I can go either way, as I have new u-bolts and also have the frame mounts that i can install to use overloads.
Any opinions?
Any opinions?
I added 2 fullsizers that a local spring shop cut for me, they are much thicker than the standard leafs, and it was night and day. I plan to be pulling a heavy GN, and want to add just a wisker more. Maybe Ill do a few overloads, and give her a shot.
A guy in town has a 93 with factory overloads, I'll check tomorrow. Talk about an odd truck. Its a CC D350 LE and He ordered it with the bench seat, power AND wide mount mirrors and the extruded aluminum full length running boards with the inset RAM logo on the side. Still working the same farm today as new.
I have 10 per side on my 93 D-350. no overloads, but 4180 Lbs of cargo capacity according to my FACTORY paperwork in the glovebox. Want a few maybe 4 springs perside? I'll give em to ya and pay the shipping!! I cant stand the ride, but it wasent exactly made for cruising either. Eventually air ride is going in, and 8 springs are coming out!
interesting my 91 w350 has 6 spings per side in the back, and one of them is what i believe you are calling overload... it's flat and short, won't even touch the others unless there is a huge load.
Originally Posted by fishin fever
does anybody know what the factory amount of springs were per pack. I have overloads but still ride like a hardtail harley over a plowed field
I just checked West Covina Dodge for springs for my truck,
PN
# 4228 424 **** 2500/ 2750 Lb. 6 Leaf @ $279.00 each
# 4228 438 **** 3250/ 3650 Lb. 7 Leaf @ $429.00 each
# 4228 434 **** 3400/ 3800 Lb. 10 Leaf @ $469.00 each
All of these were obsolete as of 1998
Jim
Does anyone know the codes under the hood to determine this?
My 92' W350 dually has 7 in the main pack and 4 in the overload pack per side. My 93' D250 has 6 in the main pack and 1 overload per side. I'll give you some advice. My W350 weighs a little more than stock since it has a heavy flatbed on it, the overloads are only an inch or so from touching and every bump you hit they slap and make a loud noise. I will be removing them and installing a set of Timbren load boosters that I've had on a lot of my other trucks. They will still slap when I hit a bump but they are quiet. They are also a lot easier to install then overload springs or overload airbags. Take a look at them.
www.timbren.com
www.timbren.com
I have the hellwig "progressive" overloads springs. they tightened up the ride a little (prolly because I used them to lift the sag out of my old factory springs) but overally, didn't make it too much worse (how much worse could it really get?
) Anyway, I feel like it's a pretty good deal at $180 a pair.
www.timbren.com
www.timbren.com
horselady
Jan 25, 2011 10:18 PM
Joe T
16
Jun 12, 2007 12:11 AM
gdh11
13
Nov 12, 2005 06:21 AM
