Nv4500 swap
Old Apr 26, 2006 | 04:42 PM
efbeason's Avatar
Nv4500 swap
Does anyone know how much trouble it would be to swap to an NV 4500 transmission from a 3-speed automatic in an '89 model Dodge? Am I way out of line for even thinking about it?? I have heard that it can be done but I am at a loss. Any information you all migh have would be greatly appreciated.
Old Apr 27, 2006 | 01:23 AM
RBergman's Avatar
i know it has been done ,
i have done the getrag to nv4500 swap i think most of that would be the same but not sure i have a lot of pictures if you want me to e-mail them to
you p.m. me you email address
Old Apr 27, 2006 | 10:41 AM
efbeason's Avatar
My email address is ed_beason@msn.com. Thanks alot!
Old Apr 27, 2006 | 11:01 AM
MJDiesel's Avatar
I was also thinking about a 4500 swap, until I decided that I may get a different pickup in a few years, so I will just replace the torque converter. You will probably need a clutch petal out of a pre-94 model pickup. The rest of the parts will need to be taken from a 94+ Dodge with the NV4500. They include a clutch slave and master cylinder, bellhousing, flywheel, adaptor plate, starter, clutch assembly, and probably a few other things that I cannot think of right now. One real problem is that the NP205 transfer case behind the automatic has a 23 spline input, while the Getrag and NV 4500 have a 29 spline output shaft. A 205 behind a Getrag could be used, or the 23 spline 'case could be machined out to allow a 29 spline input. One other thing to consider is a light duty NV4500, since it has a 23 spline output shaft. However, this transmission is only a good idea if power levels remain around stock. This webpage pretty much reiterates what I just typed. It is a good guide to this project, but you may save considerably more money by getting parts elsewhere.
http://www.high-impact.net/transmiss...88-03_auto.htm
It is a difficult project, but worth it if you can spend the time and money. Good luck!
Old Apr 27, 2006 | 12:50 PM
RBergman's Avatar
pictures sent
SilverSootXpres
Mar 23, 2010 07:18 PM
logan21sv
Mar 5, 2006 05:27 PM
Diesel-Dan
0
Jul 26, 2004 03:27 PM
OkJeeper
Apr 24, 2003 10:32 AM
