nv4500 mount pics help!!!
Old Mar 24, 2007 | 03:44 PM
swampthang's Avatar
i am in the middle of putting a nv4500hd in place of my getrag that blew up and i need a pic of the conversion mount i had to move the stock first gen crossmember back a inch or so and it lookis like i can just weld a plate on there drill two holes and bolt it down not sure if that will work or not now in the pics i have attqached you can see i am using a second gen trans nount and i need to attach it to a first gen crossmember now can i just weld the plate that you see in the pic over the oval holes in the crossmember and bolt the second gen trans mount to the welded on plate or will that be to low and put my drive shafts out of whack
JC
Attached Thumbnails nv4500 mount pics  help!!!-copy-trans-001.jpg   nv4500 mount pics  help!!!-trans-006.jpg   nv4500 mount pics  help!!!-copy-trans-004.jpg
Old Mar 24, 2007 | 09:31 PM
1stGen545's Avatar
That will work fine. I did mine kinda like that. Get an angle finder and check the angle of the flange on the 4500 and you pinion yoke and get them as close as you can to the same. Like 6* up on the pinion and 6* down on your trans or what ever angle the pinion is at. The flange and your t-case yoke will be the same. Then you can tell if you need to shim it up or not.
Old Mar 24, 2007 | 11:39 PM
swampthang's Avatar
cool thanks i will do that tomarow my new coupler should be in anyday now so i will be able to put in the t-case and the drive shafts and hopefully drive the thing did you use you stock hydro system with your 4500 or did you use one from a second gen truck ?? i got my factory one to bolt up just dont know if it has enough travel to dissengage the clutch all the way
JC
Old Mar 25, 2007 | 08:03 AM
Trebor's Avatar
I just measured mine. From the top of the BARE crossmember to the flat transmission mounting surface where the transmission mount bolts onto measures 4"
Old Mar 25, 2007 | 09:19 AM
jimlj's Avatar
Send me a PM.
edited by wannadiesel
Old Mar 25, 2007 | 11:43 AM
1stGen545's Avatar
Yes I used my stock hydro but I made my stock G-rag bell bolt to the trans. So the only thing not stock was the Trans.
Dodgin&Rammin
Jun 17, 2013 10:31 PM
thrashingcows
Apr 26, 2011 03:13 PM
SilverSootXpres
Mar 23, 2010 07:18 PM
bkoz
Apr 28, 2006 01:47 AM
grant g
Dec 28, 2003 08:35 PM
