NP205 problems
Old Mar 3, 2009 | 09:40 AM
Falcon1's Avatar
NP205 problems
I was backing my 5th wheel the other day in some mud so I put it in 4low. when I gave it some fuel I heard a ratcheting noise from underneath and no front engagement for a second . When I let off the fuel it engaged. Is it the t case or the front hubs not working correctly????? Any one know or has had this happen. It also does it on my neighbors older chev.
Old Mar 3, 2009 | 10:07 AM
92 Bob's Avatar
I'm guessing you had a hub that didn't catch right away. Were your wheels turned short when it happened ? I've had that happen a couple of times before I installed the Warn Premium hubs.
Old Mar 3, 2009 | 11:30 AM
rebal's Avatar
it could also be that you did not have the 4low pushed in all the way. common if your linkage gets a little worn
Old Mar 3, 2009 | 12:26 PM
Falcon1's Avatar
I'll try again. It did it if froward and reverse. The hubs are new warn hubs.
Old Mar 3, 2009 | 12:50 PM
GasganoFJ60's Avatar
Ditto. It can happen to the best of us...
Old Mar 4, 2009 | 09:53 AM
Falcon1's Avatar
Right on that's what it was...... Thanks for the input all.
jabcon
33
Mar 18, 2018 04:32 PM
RBergman
Dec 12, 2005 01:25 AM
SmokinFive9 4x4
Aug 19, 2005 02:08 PM
97catintenn
Feb 11, 2005 01:47 PM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
