is this normal?
is this normal?
Hello, I took the beast out for a drive the other day and noticed something that I didnt before. When I hit a pothole or big bump the front end seems to hit like there are no shocks.(hits hard) The guy I bought the truck from had the frontend rebuilt and new shocks put on about a year ago. I know the diesels are heavy and there is a lot of weight above the front tires but is this normal. I dont want to try to fix a problem that is normal for these trucks. This is on a 2wd truck. THANKS
someting must be up ,all my dodges (2wd)have had smooth rides on the front ends. look real close might be missing somthing . Broke spring weak springs ,something, shock gone bad ,somethings not normal
Does the truck sit up level or is it nose-low? There are some springs out there that must also fit Electro-Motive applications and sometimes guys have them installed to level the truck. Problem is that the springs put you all the way up on the upper bump stops, so the suspension has no down travel at all.
Hello, well I crawled under the truck today and the springs look fine. I couldnt find any cracks or breaks. Also the shocks have to be fairly new, they are still clean and not rusted yet. I dont know whats up I guess I will drive it some more and see what happens.
wannadiesel, the truck sits pretty level, maybe a tad bit nose down. I will post again someday if I ever figure it out. Thanks guys
bigbaddiesel
Mar 22, 2003 07:52 AM
tobyw
Dec 11, 2002 11:54 AM
