no boost readings
no boost readings
just got my truck running, after replacing turbo with one from a 95. i also installed pro, tranny temp, and a boost guge. all work well except boost. it doesnt even move.now, ive down some reading, could it be that the wastegate is "open" and not building pressure.with no engine mods yet, the pyro reads 1100. so im thinking that maybe it is suck and not blowin like it should??? any insight would help.
You could have the gauge plumbed wrong or the line micht be pinched or broken etc...
A quick check could be done by putting a cap with an air fitting on the intake of the compressor and pressurizing the system slowly. This should show the boost gauge works or not and you have a reference for accuracy. Be careful though when I did this I had a hard time keeping the cap from sliding off the intake of the turbo and it would go POP! no matter how tight I made the clamp. You can make a cap pressurizer out of some PVC pipe and a rubber pipe coupler from your plumbing supply.
Edwin
Edwin
ok well i feel a little stupid., drove it and it showed that i had 10 psi of boost. that was peak readins so i need to play with the fuel pin abit and i hope i do it right. this is my first diesel motor so i am nevouse about every move i make. thanks for info.
xp8103
19
May 20, 2005 08:56 AM
Barrett_Fodder
May 26, 2004 04:39 PM
tobyw
Dec 6, 2003 11:09 AM
lezmark7
Jun 28, 2003 11:50 AM
