new water pump looks wrong??
Old Nov 24, 2010 | 12:25 PM
tyssniffen's Avatar
sheesh.
so, I finally got the box with the new water pump ordered from autozone...
Duralast New/Water Pump
For your 1991 Dodge Truck W250 3/4 ton P/U 4WD 5.9L Turbo Diesel 6cyl
Part Number: BWP-726
and it looks weird.... the shaft of the pulley doesn't seem nearly long enough... nor do I see the weep hole I spent so much time looking for on the original.
what the heck? did I order the wrong part? did their website send me the wrong stuff?? I just went through and checked all the model stuff and VIN and everything...
Is there more than one kind of water pump for this engine?
Tys
Old Nov 24, 2010 | 05:32 PM
Buddy Stewert's Avatar
There is only one pump maybe the parts guy sent you one for a gas V8
Old Nov 24, 2010 | 05:58 PM
Onemoparnut's Avatar
The only difference I have heard of is a closed and open impeller design. But both will work and I think the closed impeller is better IIRC.
Old Nov 25, 2010 | 11:31 AM
jimbo486's Avatar
I searched on Autozone's website and found that BWP-726 is the right pump.
http://www.autozone.com/autozone/par...ier=61169_0_0_
A lot of times you have to stress that the 5.9L you have is the diesel. Most parts guys would assume the gasser when they here "5.9" since the older V8's were the 4.9L and 5.9L Magnums. Not sure how long ago they were first used but it's a common mistake.
Old Nov 25, 2010 | 12:39 PM
And don't forget the 5.2 magnum (318)....
Old Nov 25, 2010 | 01:01 PM
cougar's Avatar
The one I replaced on my 91 looked different also, but it fit right up and has been working fine for the last 5 years. It was made in China.
Old Nov 27, 2010 | 10:37 PM
gadget.35-06's Avatar
The VIN code usually appears on the computer so a counterman would ask if the vehicle is a diesel or gas. Unless, of course, he's a total gank.
Old Nov 28, 2010 | 06:37 PM
jimbo486's Avatar
Which is why it's commonly mistaken .
technolackey
Sep 5, 2012 04:27 PM
rockrunner
Dec 26, 2007 11:29 AM
flashgordon
Nov 20, 2007 01:16 AM
Nutcase
Jul 13, 2007 08:08 AM
bnold
Jan 1, 2007 08:37 AM
