new ve pumps?
Old May 18, 2008 | 11:13 AM
stackx2's Avatar
new ve pumps?
where is a good place to get a new ve pump for a fairly good deal. thanks,John
Old May 18, 2008 | 01:36 PM
dodgethis91cmns's Avatar
ebay sells em cheap
Old May 18, 2008 | 03:01 PM
is your pump going bad???
Old May 19, 2008 | 02:26 AM
stackx2's Avatar
ya when i park facing uphill it cranks over like a new ford before it starts and when im facing downhill it fires up on the first crank. but today it wouldnt even start unless i held my foot to the floor so i think it is going out
Old May 19, 2008 | 09:23 AM
Jschlachta's Avatar
have you checked the lift pump? you may have leak in fuel supply to the VE.
Old May 19, 2008 | 09:59 AM
pwrtripls1's Avatar
mine had a simular problem that went away when i replaced the lift pump. try that first since its only $60 and takes a few minutes.
Old May 19, 2008 | 11:44 AM
Tron's Avatar
Were are you getting a lift pump for 60 bucks. I priced a cummins one at 200 that was with company discount
Old May 19, 2008 | 11:52 AM
sdstriper's Avatar
Online. Ebay sellers often have them for under $50.
I bought one off someone on there for $36 bucks once. Brand new, Cummins p/n, not in the factory box.
Old May 19, 2008 | 11:54 AM
sdstriper's Avatar
Definately try a lift pump before spending a bunch on a rebuild VE. I would want a new lift pump for a rebuild injection pump anyway if it is not the solution to your problem.
Old May 19, 2008 | 12:38 PM
pwrtripls1's Avatar
try napa or a regular parts store. Mine is a carter brand and a little bigger in size than the stock one i replaced. it runs totaly different now with a good LP. I think mine was like $58 a few years ago when I got it from advance or pepboys, i cant remember.
Old May 20, 2008 | 10:50 PM
hardheaded's Avatar
bought mine off of ebay, its a delphi part. hasnt failed yet! 48 dollers
Old May 21, 2008 | 02:13 AM
stackx2's Avatar
ya i checked the lift pump and it is pouring the fuel out when i pump it. if it is the pump i just got a used pump off of a water pump engine that had 3000 hrs on it but it was free 90 free
Speed Shift
60
Mar 13, 2007 01:57 PM
Ilikebikes
Dec 11, 2006 10:13 PM
Dave88LX
31
Sep 7, 2006 10:10 AM
spshorsetrans1
Oct 24, 2003 12:06 PM
