New Pyro, and boost gauge
Old Oct 31, 2007 | 12:13 AM
TJE's Avatar
TJE
Well I got the new gauges in tonight. I think they are working pretty good.
Egt' at 55mph were right at 700
Boost went to about 15 when I romped on it, but dropped to close to zero when just cruising.
Let me know what #'s I should be looking at with the mod's in my sig.
Thanks, Tony
Old Oct 31, 2007 | 12:38 AM
Dean Snow's Avatar
is 15 lbs the most you got out of it? Should have been more than that? I thought stock was 18lbs of boost? Im running 28lbs and i have less mods than you do
Old Oct 31, 2007 | 08:54 AM
GasganoFJ60's Avatar
Agreed. My truck is pretty much stock and I and lay on it and get 18-19.
Did you just give it a quick romp or did you lay all the way into it through all the gears?
Old Oct 31, 2007 | 11:33 AM
ofcmarc's Avatar
Numbers look ok. T/C could be loose enough that you aren't fully loading the CTD so you won't see loads of boost.
Old Oct 31, 2007 | 12:11 PM
TJE's Avatar
TJE
Talking
I have another thread about my 3200 rpm spring. If you look at that you would understand why maybe. I had to go in this morning and move the little pump piece that has the hash marks? clock wise one tooth. I did that and now the thing runs like a scalded dog. I have not floored it yet, but when I romp on it I'm hitting about 22 to 23 boost The egt's are then about 900.
Here is the link
https://www.dieseltruckresource.com/...200+rpm+spring
P.S. Look out corvettes
Old Oct 31, 2007 | 05:56 PM
ofcmarc's Avatar
Here is the link
I saw that link. Glad things worked out that way.
P.S. My buddys 06 mustang dosen't like me
Old Oct 31, 2007 | 06:02 PM
BC847's Avatar
1st Generation Admin
So where did you mount the EGT sensor? Pre-turbo or post-turbo?
Old Oct 31, 2007 | 09:49 PM
TJE's Avatar
TJE
Pre turbo. I finally pushed it to where I got up to 1000 egt's, and 25 boost.
I can't believe what a difference there is in this truck.
Later, Tony
Onemoparnut
Jan 4, 2009 07:22 PM
Dave88LX
Feb 12, 2006 10:29 PM
Mr. Jimmy
Jan 20, 2006 03:51 PM
Igor
Sep 13, 2005 12:47 AM
royta
27
Mar 22, 2005 03:01 PM
