new guy oil pressure question
Old Aug 10, 2010 | 08:27 PM
trail grenade's Avatar
well ive been reading this forum for some time and have gathered plenty of info, and for that i thank u..
so today i finished putting in my 366 spring and denny t pin, i went out and test drove it and now when i randomly come to a stop i lose all oil pressure on the stock gauge and the idiot light comes on... it seems like its running fine, and when i start driving again it goes back to normal...
so wat say u? think its the sensor taking a poop or an oil pump going?
thanks so much for the help in advance
Old Aug 10, 2010 | 08:30 PM
ofcmarc's Avatar
Cheesy factory gauge/sender most likely. Put a real gauge on it and see what happens.
Old Aug 10, 2010 | 08:33 PM
so u think its fine to drive it 20 miles to work in the morning and throw a gauge on it there?
Old Aug 10, 2010 | 08:38 PM
Richie O's Avatar
366 Spring Chicken
Your idle may be set lower then before causing the oil pressure to get low enough to snap the light on.
Old Aug 10, 2010 | 08:42 PM
i do have it set much lower than before, but the needle drops completely off the gauge
Old Aug 10, 2010 | 08:57 PM
dieselJon's Avatar
My 93 Crown Vic does that when it needs oil.
Did you check the oil level?
Old Aug 10, 2010 | 09:18 PM
Onemoparnut's Avatar
Check the connection for the oil sender they get a little corrosion and then they go nuts sometimes. The stock oil pump is way more reliable than that crappy gauge and sender. Also make sure it is full of oil!!!
Old Aug 10, 2010 | 09:59 PM
Rick 12v CTD's Avatar
Bad sender is my guess. My truck did the exact same thing when my sender went bad. Replaced the sender and was on my way with a working oil pressure gauge.
slothrockit
Introductions / New People
Jul 5, 2008 10:25 AM
rjm022
0
Sep 16, 2007 08:33 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
