New Crossflow Head
Old Dec 28, 2008 | 12:00 AM
mhuppertz's Avatar
New Crossflow Head
I'm working on a solid model for an new, cross flow head for the Cummins, and I need the exact head bolt spacing and cylinder bore centers and spacing for the 5.9. Any of you out there have blueprint specs????
Mark
Old Dec 28, 2008 | 07:55 AM
Uh, not to be a wet blanket but the head is already a crossflow design.
Old Dec 28, 2008 | 11:19 AM
mhuppertz's Avatar
It's actually an 90deg head (the valves are in line with the head). I want to build a true cross flow with high ports so I can straighten out the flow. I can also use high ratio rockers that way.
Old Dec 28, 2008 | 01:34 PM
sdubfid's Avatar
You can already buy a redesigned billet aluminum head for 12k if I remember correctly.
Old Dec 28, 2008 | 02:02 PM
mhuppertz's Avatar
Can't find it....
Old Dec 28, 2008 | 02:55 PM
bob4x4's Avatar
Mark
I would think that you would need many more dimensions than what you are asking for.Most that do a project like this would start with an oem part on hand to have all necessary dimensions.
Bob
Old Dec 28, 2008 | 03:14 PM
RamW350 dually's Avatar
Ewww, an aluminum head on a Cummins is something I've not heard of. Not like the stock all iron engine that we know as a durable unit. The Duramax is the only engine I've heard of with aluminum cylinder heads that doesn't seem to have a problem, other then it's not the best combo to have aluminum head/iron block (heard of a lot more head gasket problems with that combo). I guess if it's for performance then one isn't too worried about it, but I'd rather stick with good ol' cast iron.
Old Dec 28, 2008 | 03:22 PM
mhuppertz's Avatar
Bob
I have a stove head to measure from, but I need the bleuprint values...
Old Dec 28, 2008 | 04:05 PM
sdubfid's Avatar
the billet head and other discussions are on another website. www.competitiondiesel.com
Sev
Aug 13, 2015 09:11 PM
sooty
Jun 14, 2011 07:49 AM
bikeboy1713
Apr 15, 2009 11:42 PM
MADSEN
Oct 7, 2004 09:43 PM
OT-OF-Here
Aug 7, 2004 07:56 PM
