New addition, LOTS of questions
Old Jul 25, 2010 | 07:50 PM
wheelo90's Avatar
Hello All,
I just bought a 91.5 5spd, with some mods. The guy i bought it from didnt seem to know much about the truck, but i got it at a great price! Now for the questions...
It has a leak on number 1 injector, right where the line goes in. what needs done to take care of this?
Driving it home today, i was playin with it a little, and noticed it will build around 30 PSI of boost, which i believe to be a little high for a H1C!
it will smoke on takeoff but definately clears up with a little air, and dont haze at idle, which is all fine with me. just wish i could find out a little more about its history, and what all has been done to the motor.
Thanks,
Wheelo
Old Jul 25, 2010 | 07:58 PM
Rick 12v CTD's Avatar
30psi is a little high (a little out of it's map range) for the h1c but it won't hurt it any and I wouldn't worry about it unless your EGTs are too high.
As for the leak on the #1 injector. I'd make sure the nut holding the injector line on is good and tight. Don't over tighten it though.
Old Jul 25, 2010 | 08:06 PM
wheelo90's Avatar
Aint 30psi a little hard on the head studs and head gasket? im assuming that the previous owner before the guy i bought it from upgraded them... hopefully.
Old Jul 25, 2010 | 08:09 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
nah they can take 35-40 typically. there are other variables too though. cylinder pressure is what youd like to know.
Old Jul 25, 2010 | 09:07 PM
At only 30 psi it's fine. Sounds like stock injectors and lots of pump tweaks, or injectors and a stock pump.
Old Jul 25, 2010 | 09:11 PM
SuperiorRam's Avatar
I would not drive with a loose feed line it will erode the line or the stick or both just my $0.02
Old Jul 26, 2010 | 08:43 PM
wheelo90's Avatar
got in a little late tonight,(typical life of a power lineman ) didnt get to investigate much, but i did try to torque the line, and it was already tight. is it a flared fitting or like a compression type? The odd thing is, even with the leak, it dont miss.
Thanks,
Wheelo
Old Jul 27, 2010 | 03:06 PM
Thanks,
Wheelo
It's got a flared end. Maybe pop it off and check to make sure it doesn't have a small piece of gunk stuck between the injector and the flare.
rbrettctd
May 31, 2007 12:34 PM
muddin4fun
Jul 22, 2004 09:11 AM
rharveysr
Jul 18, 2003 01:05 PM
