need some help
Old Oct 28, 2009 | 12:06 AM
dieselcrazyw350's Avatar
need some help
i cannot figure out the problem my truck has.
at certain rpm's it feels like it is cutting out or has a bad miss and some rpm's it feels fine???
at around 1500 it feels like its cutting out but if i go a little bit over 1500 it feels fine but then once i get at 2000 it starts to cut out again but once i go over 2000 it runs great.i replaced my lift pump and my water/separator is brand new and i also bought a pressure gauge with the tapped banjo bolt and ideling my fuel pressure is about 5psi and whn i rev it up high it still stays where it should be so im not sure.
could bad injectors be causing this? my truck has a little bit over 300,000 on it.
my truck is a 91.5 with a getrag. my smoke screw is bottomed starwheel is bottomed and the full power screw used to be only one turn back from bottomed but once it started doing this i backed it out about 1 1/2 more turns thinking i wasnt getting enough fuel but it didnt help one bit
so i have no clue as to what the problem could be.
Old Oct 28, 2009 | 10:47 AM
ppiggppenn's Avatar
Some of the IP tuners will chime in shortly, but is there any chance your fuel solenoid wire is making-breaking with certain engine vibrations, ie specific rpms? You could hot-wire it for a test run and see if anything changes.
Old Oct 28, 2009 | 05:51 PM
I think that's a very good suggestion.
Old Oct 28, 2009 | 08:02 PM
jcarrillo's Avatar
How many miles does your pump have on it?
Old Oct 28, 2009 | 09:52 PM
Benjamin b2's Avatar
i have that exact same problem, tryed backing the power screw out and it didnt help, thought i had water in the fuel, new fuel filter, and nothing seems to help, no fuel leaks, i couldnt tell you where an air leak was, it seems when i build around 15 lbs of boost or at a certain rpm it just wants to cut out, then if i hit the throttle it advances and runs good. its got a brand new ip on it and it did this before i rebuilt the pump.
Old Oct 28, 2009 | 10:29 PM
thanks i will take a look at that and see what it does.
Old Oct 28, 2009 | 10:48 PM
92smokin blacky's Avatar
Those injectors are well used with 300,000 on them. That could be causing it, they could not be poppin off right.
Old Oct 28, 2009 | 10:52 PM
jimbo486's Avatar
maybe a bad/weak lift pump not supplying enough pressure or volume to build enough case pressure?
Old Oct 28, 2009 | 11:15 PM
Tron's Avatar
I had a similar symptom and has not come back since the Ip was rebuilt. The plunger return springs were broken and the rotor a chunk off of it. Hope this is not your problem.
Old Oct 28, 2009 | 11:38 PM
i just had my pump rebuilt and i have a high presure piston pump at 15lbs, and brand new lucas pod's
Old Oct 28, 2009 | 11:40 PM
sorry for the highjack but could it be an air leak, i mean where would come from???
Old Nov 1, 2009 | 07:49 PM
*update*
ok i rigged my fuel pressure gauge into my cab temporarily and it stays 5-6 psi and when i floor it it only goes down to 4 psi.
also i decided to see what happened when i free revved it to the rpm where its the worst which is 2000 and i could here popping from the exhaust(i have a stack and had my back window open) while fuel pressure read 5 psi
Old Nov 1, 2009 | 10:25 PM
yeh i hot wired mine and it didnt help,
Old Nov 3, 2009 | 06:19 PM
Sounds like internal pump problems to me.
Old Nov 3, 2009 | 06:40 PM
i changed out the internal pump presure banjo bolt on the return line and it was plum packed with nasty stuff, probably from when i had it all apart, i replaced it and she runs like a top, loads more fuel and better responce, no more miss, also turned my regulator down to 10 psi and that seemed to help. my valves were a 15 and 30 and i adjusted those to 8 and 18, world of difference,
change out your return line banjo bolt right next to the idle screw and see how that works.
bsj04
Sep 20, 2007 08:09 AM
Mini_Donkeys
Apr 19, 2007 12:21 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
