Need to see if tires fit wheels properly
I bought a set of 17x10 wheels and just bought a new set of tires 265/75/17 will these tires fit and look right or will they be streched out to fit the rim?
I think a 7 - 8" rim would be alot better. It would probably work with a 10", but it's not recommended, and I'm not sure how tire wear will be. Obviously, airing down for traction on soft terrain would be completely out of the question.
--Eric
--Eric
Best bet is to ck the tire mfr. specs. I`m running 305/70 16 Firestone and they spec out a (IIRC) 7-9 inch rim...I`m running 10`s and they look fine. A 265 might be stretching it a bit.
How are you measuring these wheels ??
If you are measuring outside to outside, then they are actually 8-inch wheels.
05-29-2009 10:24 PM
royta
08-19-2008 10:21 PM
Txwelder
01-21-2007 11:00 PM
sakisaki400
23
12-31-2006 10:17 PM
Gary C
27
03-11-2004 07:42 PM
