Need a part number
Need a part number
Guys,
I pulled my injection pump off on Saturday and there wasn't a woodruff key in between the shaft and the gear. I just got this truck, and don't know the history. Anyway I need a key to put it back and my local cummins dealer isn't too sharp.
I found the sticky that the Bosch part number is:
1 460 023 307
Can anyone tell me what the Cummins part number is?
1 460 023 307
Being that it's part of the pump, it'll be a Bosch part only. Cummins won't be able to help you out. But as wanna said, hardware stores will have them. If you have no luck there, check with a local fuel injection shop that is an authorized Bosch dealer.
Thanks. I didn't have a key to compare it to so I wasn't sure what it was supposed to be. I finally looked up the key used on a 2144 International Combine (6bt with ve) and it says that its a standard #6 Woodruff Key. I also looked up the key used on a 75xt skid loader (4bt with VE) and it says M4x6.5x15.72. If you draw those out in cad and do the conversions, they are within thousands of each other. I'm confident that either would work.
This is what I found when I took my pump off. I'm assuming that the last person who had this pump off got the key stuck between the gear and the front of the pump housing. The key is nowhere to be found so its was either lost or is down in the belly of the beast. I can tell the front cover has been off the engine at one point so maybe it caused a little damage at one point, I'm not sure. All I know is It had been running fine for a long time (I can tell the pump hadn't been touched in quite a while) but had recently started getting fuel in the oil. Its a wonder that seal ever held the fuel back.
Guys,
1 460 023 307
1 460 023 307
I plan on putting it back together this evening. I might do some more fishing first, but I don't think there was one in there.
77machomopar
01-24-2008 05:30 AM
Bushy
07-16-2005 01:50 PM
MR. GADGET
09-04-2003 06:25 AM
rkelso98
03-14-2003 06:15 AM
